Occasionally my server does not shut down completely. It gets to a black screen but the power never actually goes off without holding the power button. When this happens, on reboot DP goes through the lengthy re-measuring/checking of the pool(s) again. I have not determined the root cause of why the system does not shut down cleanly; I don't see anything obvious in the logs, and don''t make any software updates I can relate to this; Windows Update is turned off. Is there something I can do before shutdown to ensure DP gets stopped cleanly? Can I stop the Stablebit service then shut down? Would that help? I'm guessing not? Is it the file system itself that is marking that the pool needs re-measured.
JazzMan
Win 7 x64 SP1
DP 2.2.0.852
6 answers to this question
