Hi, I enjoy Stablebit Scanner in combination with DrivePool.
Recently I switched from a Fractal Design R5 to a 24 Hot-swap Rack-mount since the R5 was so filled up I could barely put the side panel up. Now since the fans can't push the air anymore it has to "pull" or suck in the air from the front which is less efficient than the R5. Now I don't really want to keep the 3 inner 120mm fans running at 100% since that will result in a jet engine noise.
Now stablebit scanner can read the HDD temps now is there any software out there that can dynamically adjust the fan speeds based on the temperature of the HDDs? Let's say at 45degrees I want them to fully blast to keep them within a normal temp. In the R5 I had 30degrees (Celsius), now the HDD are pushing 40-50 since they are stacked closer together.
JohnKimble
8 answers to this question
