Recovered data from missing drive using Snapraid, now the data is marked as "Other" in Drivepool
I had a drive go bad, so I pulled it and replaced it.  I removed the bad drive and added the new drive back to drive pool so it would create a .PoolPart folder, then used SnapRaid to recover the data on that drive.
It all worked fine.  No data loss.
But now, all the used space on the newly-replaced drive is marked as "other" data is DrivePool.  Everything on the old drives is still marked a Unduplicated (I don't enable any data duplication).
Is this a problem or should I just ignore it?
Thanks.
I may be wrong but I think you just need to re-measure the pool.
I recently manually added some files to the hidden pool folder & they showed up as other until I re-measured the pool.
