Hi, if you go to the cog icon -> Troubleshooting -> Service log, is there any activity particularly warnings or errors?
You can also use Windows Resource Monitor to see what files DrivePool.Service.exe is scanning/writing re the duplicating.
If there's nothing obvious, you might also try stopping the duplication, running a Manage Pool -> Remeasure and then cog icon -> Ttroubleshooting -> Recheck duplication to see if that helps.
HI thank for replying. Unfortunately nothing of the above works. I do have some issues with 1 disk reporting errors in de SB scanner. That might be the source of the troubles? I am working on that now, trying to remove the faulty disk.
