I'm running DP v. 2.2.0.651 on my WHS 2012r2 Server, a 49.6TB pool. Recently I added two drives, a 6TB, replacing a damaged 6TB drive, and an 8TB.
The system properly added the duplicate files to each drive, but didn't go back and re-balance. I have the balancing settings as "SB Scanner" priority one, then "Volume Equalization" as number two. Figured that should be causing it to balance (It's set to balance immediately, with 10GB as threshold, we're way past that.)
Any thoughts, or ideas on how to get it to work? Everything is still working great, just trying to keep things tuned up.
andybflo
Good Morning!
Thanks-
-Andy
