So, before i started using DP, I had no problems creating SYMLINKS and HARDLINKS to serve up to several clients on my LAN from the Windows 10 machine's pool.
However, I noticed after creating the pool, both SMYLINK /J works, but the directories on the clients disappear and reappear with no visible pattern.
If I use /H (switch for HARDLINK), then I get "The request is not supported."
Now, if I create the symlink (/H or /J) to/from the physical drive to the hidden folder "poolPart" and run the same command, same file, everything works.
Am I doing something wrong or is this a limitation in the software?
seanvree
Setup:
Windows 10 64
physical drives in pool:
1 WD HDD 6TB (M:) (2TB used)
1 WD HDD 6TB (U:) (1TB used)
Thanks,
