Hey all! I'm using both DrivePool and Scanner. They're both generally working well but there's one problem with Scanner: Even when it's set to start/stop automatically, it isn't. The latest scans on all my drives are from late September, when I first started using it. I also recently replaced a drive in my pool and it never started scanning until I manually clicked the Start button and now it's running. I'm largely using the default scanner settings and I'm on Windows 10 Pro x64. Any ideas? Thanks!
EDIT: Hmm, interestingly, it seems to be fixed now. It was set to only do the scans between midnight and 6am, which should have been fine as this is a home server that's always on. However, I don't care when it scans so I set it to do it any time. Then it automatically started right away. We'll see if this sticks. Thanks!
Parallax Abstraction
