I've spent the last several weeks uploading a lot of data. I'm now at the very end of that upload, but CloudDrive seems to be stuck in some sort of loop. It got down to around 430MB of data left to upload, then it started trying to upload 30 chunks or so at a time, but it never actually completes the chunks. Now it says that it has over 1.1GB to upload. All of the chunks that it is trying to upload have been uploaded before. Here is a section of the log:
2:11:30.2: Warning: 0 : [IoManager:67] [W] Error writing range: Offset=807,822,426,112. Length=524,288. Thread was being aborted..
2:11:30.2: Warning: 0 : [IoManager:73] [W] Error writing range: Offset=807,822,950,400. Length=16,515,072. Thread was being aborted..
2:11:30.2: Warning: 0 : [IoManager:62] [W] Error writing range: Offset=807,864,172,544. Length=720,896. Thread was being aborted..
2:11:30.2: Warning: 0 : [IoManager:85] [W] Error writing range: Offset=807,885,471,744. Length=393,216. Thread was being aborted..
2:11:30.2: Warning: 0 : [ReadModifyWriteRecoveryImplementation:93] [W] Failed write (Chunk:38350, Offset:0x00000000 Length:0x01400500). The write operation failed, see inner exception.
2:11:30.2: Warning: 0 : [IoManager:69] [W] Error writing range: Offset=807,885,864,960. Length=14,942,208. Thread was being aborted..
2:11:30.2: Warning: 0 : [ReadModifyWriteRecoveryImplementation:52] [W] Failed write (Chunk:38521, Offset:0x00000000 Length:0x01400500). The write operation failed, see inner exception.
2:11:30.2: Warning: 0 : [IoManager:77] [W] Error writing range: Offset=807,948,517,376. Length=262,144. Thread was being aborted..
2:11:30.2: Warning: 0 : [ReadModifyWriteRecoveryImplementation:36] [W] Failed write (Chunk:38341, Offset:0x00000000 Length:0x01400500). The write operation failed, see inner exception.
2:11:30.2: Warning: 0 : [ReadModifyWriteRecoveryImplementation:83] [W] Failed write (Chunk:38349, Offset:0x00000000 Length:0x01400500). The write operation failed, see inner exception.
2:11:30.3: Warning: 0 : [ReadModifyWriteRecoveryImplementation:87] [W] Failed write (Chunk:38520, Offset:0x00000000 Length:0x01400500). The write operation failed, see inner exception.
2:11:30.3: Warning: 0 : [ReadModifyWriteRecoveryImplementation:14] [W] Failed write (Chunk:38340, Offset:0x00000000 Length:0x01400500). The write operation failed, see inner exception.
2:11:30.3: Warning: 0 : [IoManager:86] [W] Error writing range: Offset=803,941,711,872. Length=1,507,328. Thread was being aborted..
2:11:30.3: Warning: 0 : [ReadModifyWriteRecoveryImplementation:59] [W] Failed write (Chunk:38519, Offset:0x00000000 Length:0x01400500). The write operation failed, see inner exception.
2:11:30.3: Warning: 0 : [ReadModifyWriteRecoveryImplementation:48] [W] Failed write (Chunk:38523, Offset:0x00000000 Length:0x01400500). The write operation failed, see inner exception.
2:11:30.4: Warning: 0 : [ReadModifyWriteRecoveryImplementation:94] [W] Failed write (Chunk:38337, Offset:0x00000000 Length:0x01400500). The write operation failed, see inner exception.
2:11:30.4: Warning: 0 : [ReadModifyWriteRecoveryImplementation:42] [W] Failed write (Chunk:38525, Offset:0x00000000 Length:0x01400500). The write operation failed, see inner exception.
2:11:30.4: Warning: 0 : [TemporaryWritesImplementation:79] Error performing read-modify-write, marking as failed (Chunk=38343, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:30.5: Warning: 0 : [ReadModifyWriteRecoveryImplementation:68] [W] Failed write (Chunk:38345, Offset:0x00000000 Length:0x01400500). The write operation failed, see inner exception.
2:11:30.5: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:30.5: Warning: 0 : [ReadModifyWriteRecoveryImplementation:63] [W] Failed write (Chunk:38517, Offset:0x00000000 Length:0x01400500). The write operation failed, see inner exception.
2:11:30.5: Warning: 0 : [ReadModifyWriteRecoveryImplementation:65] [W] Failed write (Chunk:38346, Offset:0x00000000 Length:0x01400500). The write operation failed, see inner exception.
2:11:30.5: Warning: 0 : [IoManager:79] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:30.7: Warning: 0 : [ReadModifyWriteRecoveryImplementation:91] [W] Failed write (Chunk:38522, Offset:0x00000000 Length:0x01400500). The write operation failed, see inner exception.
2:11:30.8: Warning: 0 : [TemporaryWritesImplementation:54] Error performing read-modify-write, marking as failed (Chunk=38335, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:30.8: Warning: 0 : [ReadModifyWriteRecoveryImplementation:40] [W] Failed write (Chunk:38348, Offset:0x00000000 Length:0x01400500). The write operation failed, see inner exception.
2:11:30.8: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:30.8: Warning: 0 : [IoManager:54] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:31.0: Warning: 0 : [TemporaryWritesImplementation:92] Error performing read-modify-write, marking as failed (Chunk=38336, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:31.1: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:31.1: Warning: 0 : [IoManager:92] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:31.3: Warning: 0 : [TemporaryWritesImplementation:25] Error performing read-modify-write, marking as failed (Chunk=38342, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:31.3: Warning: 0 : [IoManager:84] [W] Error writing range: Offset=803,922,247,680. Length=18,612,224. Thread was being aborted..
2:11:31.3: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:31.4: Warning: 0 : [IoManager:25] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:31.7: Warning: 0 : [TemporaryWritesImplementation:81] Error performing read-modify-write, marking as failed (Chunk=38351, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:31.7: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:31.7: Warning: 0 : [IoManager:81] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:31.9: Warning: 0 : [IoManager:79] [W] Error writing range: Offset=804,110,991,360. Length=15,597,568. Thread was being aborted..
2:11:32.0: Warning: 0 : [TemporaryWritesImplementation:74] Error performing read-modify-write, marking as failed (Chunk=38344, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:32.0: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:32.1: Warning: 0 : [IoManager:74] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:32.2: Warning: 0 : [IoManager:54] [W] Error writing range: Offset=803,962,159,104. Length=2,031,616. Thread was being aborted..
2:11:32.4: Warning: 0 : [TemporaryWritesImplementation:93] Error performing read-modify-write, marking as failed (Chunk=38350, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:32.4: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:32.5: Warning: 0 : [IoManager:93] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:32.5: Warning: 0 : [IoManager:92] [W] Error writing range: Offset=803,983,458,304. Length=1,703,936. Thread was being aborted..
2:11:32.7: Warning: 0 : [TemporaryWritesImplementation:52] Error performing read-modify-write, marking as failed (Chunk=38521, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:32.7: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:32.8: Warning: 0 : [IoManager:52] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:32.9: Warning: 0 : [IoManager:25] [W] Error writing range: Offset=804,090,019,840. Length=16,973,824. Thread was being aborted..
2:11:33.0: Warning: 0 : [TemporaryWritesImplementation:36] Error performing read-modify-write, marking as failed (Chunk=38341, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:33.0: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:33.1: Warning: 0 : [IoManager:36] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:33.1: Warning: 0 : [IoManager:81] [W] Error writing range: Offset=804,279,091,200. Length=15,335,424. Thread was being aborted..
2:11:33.3: Warning: 0 : [TemporaryWritesImplementation:87] Error performing read-modify-write, marking as failed (Chunk=38520, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:33.3: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:33.3: Warning: 0 : [IoManager:87] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:33.4: Warning: 0 : [IoManager:74] [W] Error writing range: Offset=804,131,962,880. Length=9,961,472. Thread was being aborted..
2:11:33.5: Warning: 0 : [TemporaryWritesImplementation:83] Error performing read-modify-write, marking as failed (Chunk=38349, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:33.6: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:33.6: Warning: 0 : [IoManager:83] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:33.8: Warning: 0 : [IoManager:93] [W] Error writing range: Offset=804,257,792,000. Length=9,371,648. Thread was being aborted..
2:11:33.8: Warning: 0 : [TemporaryWritesImplementation:14] Error performing read-modify-write, marking as failed (Chunk=38340, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:33.9: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:33.9: Warning: 0 : [IoManager:14] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:34.2: Warning: 0 : [TemporaryWritesImplementation:59] Error performing read-modify-write, marking as failed (Chunk=38519, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:34.2: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:34.2: Warning: 0 : [IoManager:59] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:34.3: Warning: 0 : [IoManager:52] [W] Error writing range: Offset=807,843,921,920. Length=16,842,752. Thread was being aborted..
2:11:34.4: Warning: 0 : [IoManager:36] [W] Error writing range: Offset=804,088,250,368. Length=1,769,472. Thread was being aborted..
2:11:34.5: Warning: 0 : [TemporaryWritesImplementation:48] Error performing read-modify-write, marking as failed (Chunk=38523, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:34.5: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:34.5: Warning: 0 : [IoManager:48] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:34.7: Warning: 0 : [IoManager:87] [W] Error writing range: Offset=807,843,725,312. Length=196,608. Thread was being aborted..
2:11:34.8: Warning: 0 : [TemporaryWritesImplementation:42] Error performing read-modify-write, marking as failed (Chunk=38525, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:34.8: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:34.8: Warning: 0 : [IoManager:42] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:35.0: Warning: 0 : [IoManager:83] [W] Error writing range: Offset=804,256,940,032. Length=851,968. Thread was being aborted..
2:11:35.1: Warning: 0 : [TemporaryWritesImplementation:94] Error performing read-modify-write, marking as failed (Chunk=38337, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:35.1: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:35.2: Warning: 0 : [IoManager:94] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:35.2: Warning: 0 : [IoManager:14] [W] Error writing range: Offset=804,048,076,800. Length=9,502,720. Thread was being aborted..
2:11:35.4: Warning: 0 : [TemporaryWritesImplementation:63] Error performing read-modify-write, marking as failed (Chunk=38517, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:35.4: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:35.5: Warning: 0 : [IoManager:63] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:35.6: Warning: 0 : [IoManager:59] [W] Error writing range: Offset=807,801,978,880. Length=19,595,264. Thread was being aborted..
2:11:35.7: Warning: 0 : [TemporaryWritesImplementation:68] Error performing read-modify-write, marking as failed (Chunk=38345, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:35.7: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:35.8: Warning: 0 : [IoManager:68] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:35.9: Warning: 0 : [IoManager:48] [W] Error writing range: Offset=807,906,770,944. Length=65,536. Thread was being aborted..
2:11:36.1: Warning: 0 : [TemporaryWritesImplementation:65] Error performing read-modify-write, marking as failed (Chunk=38346, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:36.1: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:36.1: Warning: 0 : [IoManager:42] [W] Error writing range: Offset=807,928,070,144. Length=15,335,424. Thread was being aborted..
2:11:36.2: Warning: 0 : [IoManager:65] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:36.4: Warning: 0 : [TemporaryWritesImplementation:91] Error performing read-modify-write, marking as failed (Chunk=38522, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:36.4: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:36.5: Warning: 0 : [IoManager:91] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:36.5: Warning: 0 : [IoManager:94] [W] Error writing range: Offset=803,985,162,240. Length=14,483,456. Thread was being aborted..
2:11:37.0: Warning: 0 : [IoManager:63] [W] Error writing range: Offset=807,760,232,448. Length=17,039,360. Thread was being aborted..
2:11:37.1: Warning: 0 : [IoManager:68] [W] Error writing range: Offset=804,173,447,168. Length=458,752. Thread was being aborted..
2:11:37.1: Warning: 0 : [TemporaryWritesImplementation:40] Error performing read-modify-write, marking as failed (Chunk=38348, Offset=0x00000000, Length=0x01400500). The write operation failed, see inner exception.
2:11:37.1: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. The write operation failed, see inner exception.
2:11:37.1: Warning: 0 : [IoManager:40] Error performing read-modify-write I/O operation on provider. Retrying. The write operation failed, see inner exception.
2:11:37.7: Warning: 0 : [IoManager:65] [W] Error writing range: Offset=804,191,338,496. Length=3,538,944. Thread was being aborted..
2:11:37.7: Warning: 0 : [IoManager:91] [W] Error writing range: Offset=807,864,893,440. Length=18,874,368. Thread was being aborted..
2:11:38.3: Warning: 0 : [IoManager:40] [W] Error writing range: Offset=804,236,492,800. Length=327,680. Thread was being aborted..
2:12:10.0: Warning: 0 : [ApiGoogleDrive:32] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:10.0: Warning: 0 : [ApiHttp:32] HTTP protocol exception (Code=ServiceUnavailable).
2:12:10.0: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,366ms and retrying.
2:12:10.0: Warning: 0 : [ApiGoogleDrive:41] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:10.0: Warning: 0 : [ApiHttp:41] HTTP protocol exception (Code=ServiceUnavailable).
2:12:10.0: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,484ms and retrying.
2:12:10.0: Warning: 0 : [ApiGoogleDrive:70] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:10.0: Warning: 0 : [ApiHttp:70] HTTP protocol exception (Code=ServiceUnavailable).
2:12:10.0: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,579ms and retrying.
2:12:11.1: Warning: 0 : [ApiGoogleDrive:82] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:11.1: Warning: 0 : [ApiHttp:82] HTTP protocol exception (Code=ServiceUnavailable).
2:12:11.1: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,150ms and retrying.
2:12:11.1: Warning: 0 : [ApiGoogleDrive:88] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:11.1: Warning: 0 : [ApiHttp:88] HTTP protocol exception (Code=ServiceUnavailable).
2:12:11.1: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,384ms and retrying.
2:12:11.1: Warning: 0 : [ApiGoogleDrive:28] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:11.1: Warning: 0 : [ApiHttp:28] HTTP protocol exception (Code=ServiceUnavailable).
2:12:11.1: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,549ms and retrying.
2:12:11.2: Warning: 0 : [ApiGoogleDrive:39] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:11.2: Warning: 0 : [ApiHttp:39] HTTP protocol exception (Code=ServiceUnavailable).
2:12:11.2: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,494ms and retrying.
2:12:11.2: Warning: 0 : [ApiGoogleDrive:4] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:11.2: Warning: 0 : [ApiHttp:4] HTTP protocol exception (Code=ServiceUnavailable).
2:12:11.2: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,298ms and retrying.
2:12:11.2: Warning: 0 : [ApiGoogleDrive:66] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:11.2: Warning: 0 : [ApiHttp:66] HTTP protocol exception (Code=ServiceUnavailable).
2:12:11.2: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,199ms and retrying.
2:12:11.9: Warning: 0 : [ApiGoogleDrive:56] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:11.9: Warning: 0 : [ApiHttp:56] HTTP protocol exception (Code=ServiceUnavailable).
2:12:11.9: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,964ms and retrying.
2:12:12.1: Warning: 0 : [ApiGoogleDrive:8] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:12.1: Warning: 0 : [ApiHttp:8] HTTP protocol exception (Code=ServiceUnavailable).
2:12:12.1: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,605ms and retrying.
2:12:12.8: Warning: 0 : [ApiGoogleDrive:28] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:12.8: Warning: 0 : [ApiHttp:28] HTTP protocol exception (Code=ServiceUnavailable).
2:12:12.8: Warning: 0 : [ApiHttp] Server is throttling us, waiting 2,602ms and retrying.
2:12:12.9: Warning: 0 : [ApiGoogleDrive:4] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:12.9: Warning: 0 : [ApiHttp:4] HTTP protocol exception (Code=ServiceUnavailable).
2:12:12.9: Warning: 0 : [ApiHttp] Server is throttling us, waiting 2,190ms and retrying.
2:12:12.9: Warning: 0 : [ApiGoogleDrive:73] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:12.9: Warning: 0 : [ApiHttp:73] HTTP protocol exception (Code=ServiceUnavailable).
2:12:12.9: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,725ms and retrying.
2:12:13.0: Warning: 0 : [ApiGoogleDrive:39] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:13.0: Warning: 0 : [ApiHttp:39] HTTP protocol exception (Code=ServiceUnavailable).
2:12:13.0: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,079ms and retrying.
2:12:13.0: Warning: 0 : [ApiGoogleDrive:69] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:13.0: Warning: 0 : [ApiHttp:69] HTTP protocol exception (Code=ServiceUnavailable).
2:12:13.0: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,279ms and retrying.
2:12:13.1: Warning: 0 : [ApiGoogleDrive:93] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:13.1: Warning: 0 : [ApiHttp:93] HTTP protocol exception (Code=ServiceUnavailable).
2:12:13.1: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,121ms and retrying.
2:12:13.1: Warning: 0 : [ApiGoogleDrive:88] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:13.1: Warning: 0 : [ApiHttp:88] HTTP protocol exception (Code=ServiceUnavailable).
2:12:13.1: Warning: 0 : [ApiHttp] Server is throttling us, waiting 2,326ms and retrying.
2:12:14.6: Warning: 0 : [ApiGoogleDrive:69] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:14.6: Warning: 0 : [ApiHttp:69] HTTP protocol exception (Code=ServiceUnavailable).
2:12:14.6: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,177ms and retrying.
2:12:14.6: Warning: 0 : [ApiGoogleDrive:14] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:14.6: Warning: 0 : [ApiHttp:14] HTTP protocol exception (Code=ServiceUnavailable).
2:12:14.6: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,117ms and retrying.
2:12:14.7: Warning: 0 : [ApiGoogleDrive:93] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:14.7: Warning: 0 : [ApiHttp:93] HTTP protocol exception (Code=ServiceUnavailable).
2:12:14.7: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,836ms and retrying.
2:12:14.8: Warning: 0 : [ApiGoogleDrive:73] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:14.8: Warning: 0 : [ApiHttp:73] HTTP protocol exception (Code=ServiceUnavailable).
2:12:14.8: Warning: 0 : [ApiHttp] Server is throttling us, waiting 2,842ms and retrying.
2:12:14.9: Warning: 0 : [ApiGoogleDrive:87] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:14.9: Warning: 0 : [ApiHttp:87] HTTP protocol exception (Code=ServiceUnavailable).
2:12:14.9: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,019ms and retrying.
2:12:15.0: Warning: 0 : [ApiGoogleDrive:48] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:15.0: Warning: 0 : [ApiHttp:48] HTTP protocol exception (Code=ServiceUnavailable).
2:12:15.0: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,350ms and retrying.
2:12:15.1: Warning: 0 : [ApiGoogleDrive:68] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:15.1: Warning: 0 : [ApiHttp:68] HTTP protocol exception (Code=ServiceUnavailable).
2:12:15.1: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,412ms and retrying.
2:12:15.1: Warning: 0 : [ApiGoogleDrive:4] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:15.1: Warning: 0 : [ApiHttp:4] HTTP protocol exception (Code=ServiceUnavailable).
2:12:15.1: Warning: 0 : [ApiHttp] Server is throttling us, waiting 4,498ms and retrying.
2:12:15.9: Warning: 0 : [ApiGoogleDrive:69] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:15.9: Warning: 0 : [ApiHttp:69] HTTP protocol exception (Code=ServiceUnavailable).
2:12:15.9: Warning: 0 : [ApiHttp] Server is throttling us, waiting 2,704ms and retrying.
2:12:15.9: Warning: 0 : [ApiGoogleDrive:79] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:15.9: Warning: 0 : [ApiHttp:79] HTTP protocol exception (Code=ServiceUnavailable).
2:12:15.9: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,387ms and retrying.
2:12:16.1: Warning: 0 : [ApiGoogleDrive:14] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:16.1: Warning: 0 : [ApiHttp:14] HTTP protocol exception (Code=ServiceUnavailable).
2:12:16.1: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,764ms and retrying.
2:12:17.2: Warning: 0 : [ApiGoogleDrive:92] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:17.2: Warning: 0 : [ApiHttp:92] HTTP protocol exception (Code=ServiceUnavailable).
2:12:17.2: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,696ms and retrying.
2:12:17.2: Warning: 0 : [ApiGoogleDrive:52] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:17.2: Warning: 0 : [ApiHttp:52] HTTP protocol exception (Code=ServiceUnavailable).
2:12:17.2: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,241ms and retrying.
2:12:19.6: Warning: 0 : [ApiHttp:83] HTTP protocol exception (Code=Forbidden).
2:12:19.6: Warning: 0 : [ApiHttp:87] HTTP protocol exception (Code=Forbidden).
2:12:19.7: Warning: 0 : [ApiGoogleDrive:83] Google Drive returned error (rateLimitExceeded): Rate Limit Exceeded
2:12:19.7: Warning: 0 : [ApiGoogleDrive:68] Google Drive returned error (rateLimitExceeded): Rate Limit Exceeded
2:12:19.7: Warning: 0 : [ApiHttp:83] HTTP protocol exception (Code=Forbidden).
2:12:19.7: Warning: 0 : [ApiHttp:68] HTTP protocol exception (Code=Forbidden).
2:12:19.7: Warning: 0 : [ReadModifyWriteRecoveryImplementation:68] [W] Failed write (Chunk:38523, Offset:0x00000000 Length:0x01400500). Rate Limit Exceeded
2:12:19.7: Warning: 0 : [ApiGoogleDrive:87] Google Drive returned error (rateLimitExceeded): Rate Limit Exceeded
2:12:19.7: Warning: 0 : [ApiHttp:87] HTTP protocol exception (Code=Forbidden).
2:12:19.7: Warning: 0 : [ApiGoogleDrive:4] Google Drive returned error (rateLimitExceeded): Rate Limit Exceeded
2:12:19.7: Warning: 0 : [ApiHttp:4] HTTP protocol exception (Code=Forbidden).
2:12:19.7: Warning: 0 : [ReadModifyWriteRecoveryImplementation:4] [W] Failed write (Chunk:38335, Offset:0x00000000 Length:0x01400500). Rate Limit Exceeded
2:12:19.9: Warning: 0 : [TemporaryWritesImplementation:68] Error performing read-modify-write, marking as failed (Chunk=38523, Offset=0x00000000, Length=0x01400500). Rate Limit Exceeded
2:12:19.9: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. Rate Limit Exceeded
2:12:19.9: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing shared partial write. Rate Limit Exceeded
2:12:19.9: Warning: 0 : [IoManager:68] HTTP error (Forbidden) performing I/O operation on provider.
2:12:19.9: Warning: 0 : [IoManager:68] Error performing read-modify-write I/O operation on provider. Retrying. Rate Limit Exceeded
2:12:19.9: Warning: 0 : [IoManager:65] HTTP error (Forbidden) performing I/O operation on provider.
2:12:20.0: Warning: 0 : [IoManager:65] Error performing read-modify-write I/O operation on provider. Retrying. Rate Limit Exceeded
2:12:20.2: Warning: 0 : [TemporaryWritesImplementation:4] Error performing read-modify-write, marking as failed (Chunk=38335, Offset=0x00000000, Length=0x01400500). Rate Limit Exceeded
2:12:20.2: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing master partial write. Rate Limit Exceeded
2:12:20.2: Warning: 0 : [WholeChunkIoImplementation] Error on write when performing shared partial write. Rate Limit Exceeded
2:12:20.2: Warning: 0 : [IoManager:4] HTTP error (Forbidden) performing I/O operation on provider.
2:12:20.2: Warning: 0 : [IoManager:4] Error performing read-modify-write I/O operation on provider. Retrying. Rate Limit Exceeded
2:12:20.2: Warning: 0 : [IoManager:96] HTTP error (Forbidden) performing I/O operation on provider.
2:12:20.2: Warning: 0 : [IoManager:96] Error performing read-modify-write I/O operation on provider. Retrying. Rate Limit Exceeded
2:12:20.5: Warning: 0 : [ApiGoogleDrive:96] Google Drive returned error (notFound): File not found: children
2:12:20.5: Warning: 0 : [ApiGoogleDrive:4] Google Drive returned error (notFound): File not found: children
2:12:20.5: Warning: 0 : [ApiHttp:96] HTTP protocol exception (Code=NotFound).
2:12:20.5: Warning: 0 : [ApiHttp:4] HTTP protocol exception (Code=NotFound).
2:12:20.7: Warning: 0 : [ApiGoogleDrive:83] Google Drive returned error (notFound): File not found: children
2:12:20.7: Warning: 0 : [ApiHttp:83] HTTP protocol exception (Code=NotFound).
2:12:20.9: Warning: 0 : [ApiGoogleDrive:96] Google Drive returned error (notFound): File not found: children
2:12:20.9: Warning: 0 : [ApiHttp:96] HTTP protocol exception (Code=NotFound).
2:12:20.9: Warning: 0 : [ApiGoogleDrive:4] Google Drive returned error (notFound): File not found: children
2:12:20.9: Warning: 0 : [ApiHttp:4] HTTP protocol exception (Code=NotFound).
2:12:21.0: Warning: 0 : [ApiGoogleDrive:68] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:21.0: Warning: 0 : [ApiHttp:68] HTTP protocol exception (Code=ServiceUnavailable).
2:12:21.0: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,803ms and retrying.
2:12:21.0: Warning: 0 : [ApiGoogleDrive:65] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:21.0: Warning: 0 : [ApiHttp:65] HTTP protocol exception (Code=ServiceUnavailable).
2:12:21.0: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,917ms and retrying.
2:12:21.2: Warning: 0 : [ApiGoogleDrive:87] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:21.2: Warning: 0 : [ApiHttp:87] HTTP protocol exception (Code=ServiceUnavailable).
2:12:21.2: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,396ms and retrying.
2:12:21.2: Warning: 0 : [ApiGoogleDrive:83] Google Drive returned error (userRateLimitExceeded): User Rate Limit Exceeded
2:12:21.2: Warning: 0 : [ApiHttp:83] HTTP protocol exception (Code=ServiceUnavailable).
2:12:21.2: Warning: 0 : [ApiHttp] Server is throttling us, waiting 1,220ms and retrying.
2:12:23.1: Warning: 0 : [ApiGoogleDrive:87] Google Drive returned error (notFound): File not found: children
2:12:23.1: Warning: 0 : [ApiHttp:87] HTTP protocol exception (Code=NotFound).
Once the upload errors out, it waits a minute, and then tries to upload all of the same chunks again, before getting the same set of errors. I have tried betas 739, 730, and 722. All produce the same errors.
Any idea what's going on?
I should also mention that I am using CloudDrive in conjunction with DrivePool, and uploading this data by way of specifying a series of folders with the file placement balancer.
