I have been running two disks at the same time on the same controller as we discussed last night
Have noticed some odd behaviour
if you look closely at the bottom profiles you will see that scanner is alternating between disks - although it favours Disk 1 slightly more than Disk 2 - Disk 1 started first and within a few seconds Disk 2
Disk 1 has finished and Disk 2 is about 45 mins behind - again odd as same type of disks and normally show very similar performance
Also the "Active Time" graphs are odd as its saying the disk is 98%-100% when clearly its not - because when a disk is 100% active scanner is not reading any data?
Accept some of this might be MS but overall a bit odd
Spider99 100
Chris
T
