Chris
Just looking at Scanner and Maps when i had something i had not seen before
Selected c: drive clicked on volume map and i get
but no unmounted volume on machine?
Scanner 3103 beta
Is this picking up the Sys reserved partition?
Yes, the "Unmounted volume" is the "System Reserved" partition.
By "unmounted", it means that it's not mounted to a drive letter or folder path.
If you scan it, you'll see a number of boot related files. So DEFINITELY the System Reserved partition.
Ironically, you only see the "C:\" drive on UEFI systems.
