Hi, firstly thanks for a great set of StableBit programs, nicely designed and explained. I've just started using DrivePool properly after buying the bundle two years ago and all is working nicely with two NVME 4TB pools setup so far (I'm putting a lot of trust into DrivePool as I move all my data around finally to sort it out once and for all!).
My question relates to whether the speed of copying files to a pool is reduced due to having to copy things twice (for duplication)? I ask because I just added another 4-way NVME PCIe card and at the same time also turned on pool duplication to secure my data better. However, I noticed that my copying speeds seem to have roughly halved from an NVME drive (outside the pool) to a pool made up of NVME drives.
Before setting duplication I was seeing copying speeds roughly averaging 1.2GBps in transfer speed to that pool, now it's more like 600MBps (with 2 x duplication now on).
So my thought is, either the duplication makes initial copying to the pool take twice as long, or maybe it's something to do with adding the new NVME card which may have slowed things down? (I did a search on the forum and manual but didn't spot anything that may help answer my question).
My system should cope with the extra card, it's got enough PCIe lanes and x16 PCIe slots (a Dell Precision T7910, 2xXeon, 128GB RAM, Win 10).
MrArtist
Would be grateful for your thoughts (anyone).
