JoeS Posted June 9, 2016 Posted June 9, 2016 Hi, please help. Since a week or so, DrivePool complains about a disk missing, but it's actually there. Also in Disk Management A picture, says more than a thousand word: https://www.dropbox.com/s/eds8yc2i3o4j6g5/Screenshot%202016-06-09%2011.22.41.png Quote
0 JoeS Posted June 10, 2016 Author Posted June 10, 2016 Should I just remove the drive and add it again? Problem ist, I only have unduplicated data on it... Quote
0 Quinn Posted June 10, 2016 Posted June 10, 2016 If you add a drive letter to the "missing" disk from within Disk Management, are you able to see your data? If the unduplicated data was previously added to the DrivePool drive, it'll be in a hidden PoolPart folder... Also, the screenshot shows that there is no data on the DrivePool volume (N:), just on the individual drives (everything appears as "Other")...have you moved/copied any data to N:? Quote
0 JoeS Posted June 13, 2016 Author Posted June 13, 2016 yeah, I'm able to see the data there. should I just move it out of the hidden poolpart folder and then remove the disk in drivepool and readd it? Yes, I have moved/copied data to N:, exclusivly, since I haven't give the other disk a drive letter, I just use it as a big homogenous pool without duplication because it's just suppose to be the backup of the backup Quote
0 JoeS Posted June 13, 2016 Author Posted June 13, 2016 I just did that. It worked. Yeah! Also another little Bug Report. If you press ESC in one of the config dialogs, it still accept the changes you made instead of reversing it. Like it would if you pressed Apply. Found the counterintuitive Quote
0 Christopher (Drashna) Posted June 13, 2016 Posted June 13, 2016 Well, no picture for me, so .... That said, what version of StableBit DrivePool are you using specifically? And sometimes, resetting the settings will fix this issue. Also, what window was applying the settings when you hit Escape? Quote
JoeS
