I've made a VM in Hyper-V to get a VPN connection inside a controlled environment, using xubuntu, and to play aorund with a linux distribution.
I would like to add my D: drive from local to the VM. Read that it was possible if you made the drive go offline with disk management. I did that and also tried to disable drivepool service.
My problem is that it cannot be seen in the Hyper-V environment under VM settings, SCSI controller.
Am I doing something wrong or is there a tweak I'm not aware of?
Valdimarsson
Best regards
Johann Valdimarsson
