HellDiverUK Posted February 23, 2016 Posted February 23, 2016 Attached is a screenshot of what happens when I try to install SSD Optimizer. Can you spot the problem? Quote
0 Christopher (Drashna) Posted February 23, 2016 Posted February 23, 2016 Make sure you have the right architecture for the installer. if you do, try right clicking on the installer and select "uninstall", and then try reinstalling. If that doesn't help, then let me know, and I'll post alternative instructions to get it installed. Quote
0 HellDiverUK Posted February 23, 2016 Author Posted February 23, 2016 I've tried both the x86 and x64 versions, DrivePool is the x64 version, as is Win 10 Pro. I also tried the "run as previous version of Windows" thing in the compatibility settings. Quote
0 HellDiverUK Posted February 23, 2016 Author Posted February 23, 2016 It's working, a reboot, an uninstall, another reboot and it worked. Quote
0 Christopher (Drashna) Posted February 23, 2016 Posted February 23, 2016 It's working, a reboot, an uninstall, another reboot and it worked. Lol, naturally. After I had a long post all typed out. And yeah, sometimes the WIndows Installer stuff doesn't give good error messages. If this happens in the future (or if anyone else experiences similiar), this should help: If you could run the following command from a command prompt: msiexec /a DrivePool.SSDOptimizerPlugin.Setup_1.0.3.5_x64.msi /Lime SSDOptimizer.log Quote
0 HellDiverUK Posted February 23, 2016 Author Posted February 23, 2016 Will do. Quick question, do I just set up my file placement rules as normal now? Quote
0 Christopher (Drashna) Posted February 23, 2016 Posted February 23, 2016 Well, that shows successful. Prior to rebooting, it probably would have mentioned a pending reboot, or the like. But who knows. Quote
0 HellDiverUK Posted February 23, 2016 Author Posted February 23, 2016 Aye, I realised what you meant after I posted, so I edited. Quote
0 Christopher (Drashna) Posted February 24, 2016 Posted February 24, 2016 Not a problem. ANd yes, just set up stuff as normal. Though, if you're using the file placement rules, you may want to change the overall balancing settings (as mentioned in the "Notes" for the balancer). Quote
HellDiverUK
8 answers to this question
