Setup, 4 drives using the onboard controller and 9 drives using a raid controller.
So the pool is 13 drives, so the onboard controller died, so 4 drives went missing.
I can connect them via usb and still get the data off of them, but they are marked missing in drive pool.
I bought a few drives to add to the raid controller so i can move the data off the 4 drives.
I can physcially get to the hard drives data via windows explorer whenever I plug the drive into my usb enclosure, but Drivepool still says it's missing.
When I try to remove it from DP, it says it can't remove b/c i have missing disk.
Would moving the data from the hidden folder (old 4 drives) to the new drives hidden folder (just added to the pool) work?
myktek
Not sure how I should proceed.
btw, all the data is unduplicated.
DrivePool 2.1.1.561 on Windows 7 64bit.
