Having just had a drive die (basically ended up being a DOA started to fail after 8 days up time).
Is it possible to have scanner send me a weekly "status" email?
Basically I'd like scanner to "let me know everything is ok" that way if I don't get this email I can start to investigate.
I also had issues where the drive failing would stop the network from working (no idea why this happened) which meant the scanner failure emails weren't getting sent.
I'd notice the server network failure (ping still worked but nothing else), reboot the box and the failure notifications would then hit my inbox, which would be way to late if it went unnoticed for too long.
Second Q:
Does Scanner have remote management similar to drive pool?
Would be great to be able to open that up instead of having to RDP in to check health...
mentalinc
Hi
Second Q:
Thanks
