Pål Andreassen 1 Posted December 5, 2015 Share Posted December 5, 2015 Had an old 500 GB drive fail. Removed it from the pool. Shutdown server. Removed disk physically from server. Replaced with new 4 TB drive. Turn on server and adds new drive to pool. Everything seems to be good. Except that DP is stuck at 6% "checking". I let in run for two days. Then I rebooted the server. Started at 0% again and it's now stuck on 6% again. Total pool size is 14 TB on 8 disks. Any ideas? Quote Link to post Share on other sites
0 Christopher (Drashna) 618 Posted December 7, 2015 Share Posted December 7, 2015 What OS are you using specifically? What version of StableBit DrivePool are you using? If you're not, please upgrade ot the public beta build: StableBit.DrivePool_2.2.0.659_x64_BETA.exe Do you have any antivirus, backup or disk tools installed on the system? Could you do this: http://wiki.covecube.com/StableBit_DrivePool_Q2159701 Also, do any of the disks in your pool have any SMART errors or other errors? And could you enable file system logging, restart the measuring, and when it gets "stuck", stop the logging and upload the logs: http://wiki.covecube.com/StableBit_DrivePool_2.x_Log_Collection Quote Link to post Share on other sites
0 Pål Andreassen 1 Posted December 8, 2015 Author Share Posted December 8, 2015 OS i Windows Server 2012 R2 Essentials StableBit version is 2.1.1.561 After two days it has moved on, and it's now at 18%. So it's moving quite fast up to 6%, then very slow from there on. I'll start with updating to the bate and take it from there. None of the disks (except the one I removed) have any smart warning. Quote Link to post Share on other sites
0 Pål Andreassen 1 Posted December 9, 2015 Author Share Posted December 9, 2015 Upgraded to latest beta and after a few hours the pool was checked, balanced and back in order. Thanks for the help. Quote Link to post Share on other sites
0 Christopher (Drashna) 618 Posted December 10, 2015 Share Posted December 10, 2015 Glad to hear that the new version helped! There are a number of optimizations and tweaks to the measuring to help prevent it from running into issues. Quote Link to post Share on other sites
Pål Andreassen 1
Any ideas?
