How to move data before pulling a drive
DenSataniskeHest
how do I remove a drive from a pool, making stable bit remove all data itself? Or should I remove the data manually?
I got a drive that I want to replace my plan is to add a new drive let it sync data around and then remove the old. I'm running a pool of disk without any duplication of data
Yes.
Files would only be left on the old drive if you tick the force damaged drive removal option (and then only unreadable files) or if you tick the archival option (in which case it would make copies of the files instead of moving them).
