I have been trying out Scanner for the past 3 days. Love it. Tried it about a year ago, it couldn't get SMART for all my drives from the HBA and the external enclosures. Now it does. Woot woot. I have a couple of questions though:
1. How safe is having no duplication in the DrivePool while running Scanner? I know there cannot be a definitive answer, but just from experience... How much chance is there that scanner will be able to warn me before the drive goes R.I.P.? I am asking for the very cost conscientious reason: do I or don't I duplicate my 50TB+ movies collection? Movies are pretty easy to replace. Although, it takes time and some tedious work. Case A: If there is little to no chance that scanner will warn me in time, I may need to bite the bullet and buy a bunch more hdds, which gets too expensive quite fast... At least I save on time and avoid potential headaches. Case B: Scanner is quite good at predicting disasters and I save a ton of money. That would be awesome.
2. Why is there no indication of SMART warning in the list of drives? Is the system tray notification the only place for it, and if so, is it reliable 100%? I'd hate to miss some disaster warnings.
3. Most of my drives are in 4 external 16 bay enclosures, connected via 4 external mini SAS SFF-8088 cables to the LSI 9201-16e HBA, which to my knowledge has 4 dedicated 6Gb/s links, one for each port. In this case scanner should be able to run 4 concurrent scans on the HBA without penalty, right? Please correct me, if I'm wrong.
4. Which option in the settings is for setting more than one concurrent scan job per controller? Advanced Settings > Configuration Properties > ScanMaximumConcurent ?
5. Is there any way to set "drive groups", so that scanner would not run concurrent jobs on the same link?
6. Or maybe scanner is smart enough and is able to test and auto-magically detect which drives to scan when, so they would not bog down one another? I see something probably related to this in Settings > Throttling > Do not interfere with other disks on the same controller (also Clear performance data..., whatever that means).
7. How does "ignoring SMART warnings" work? I see there is an option on the system tray popup window: Never warn me about SMART warnings/failures. I guess this one is pretty self-explanatory - I check this and never ever get warned about SMART issues, yes?
8. There is a button Ignore warning... at the bottom of the SMART popup window. What does this one do exactly? If I press it, would I ignore only current warning(s) or all future warnings for this drive? What about this same warning, but getting worse, eg: increased pending, reallocated or uncorrectable sector counts?
9 . About bad sectors. I have one drive's SMART reporting:
Reallocated Sector Count: 0
Current Pending Sector Count: 1
Uncorrectable Sector Count: 1
What should I do? I have read many people opinions, that when u start getting bad sectors, it's a slippery slope, kinda like snowball effect and the drive is pretty much considered doomed... How true is that? Should I bin it? If no, how do I fix it? Full format or chkdsk /r or maybe scanner is actually able to fix it? I moved all files but 1 from the drive already. 1 was giving me cyclic redundancy errors. I was thinking of using SpinRite to try and recover it, if you have any suggestion for a better way to recover the file, please let me know.
10. Scanner warned me about another 2 driver with way more severe sector counts:
Current Pending Sector Count: 331
Uncorrectable Sector Count: 0
and
Current Pending Sector Count: 1464
Uncorrectable Sector Count: 1025
What is confusing, is both drives, even the second one shows the same messages for all sector count parameters: "The drive is operating within manufacturer specified tolerances." What the hell? Does this mean these drives are considered in good condition and usable? I was not able to move ~30 files from the second one, cyclic errors. Gonna need to try and recover also.
11. From reading about scanner in this blogpost: Why using StableBit Scanner is a good idea, I gather scanner has some ability to try and recover unreadable files. How does that work? If it succeeds, where does it put the files? How do I do it? Is there a special command/task to launch? Should I try spinrite if scanner fails to recover? Or is it futile?
Regarding questions 5 & 6: if it is not possible to set drive groups and scanner is not smart enough on it's own, I would very much like to add a request for this feature to be added to scanner in the future. I am thinking in the future terms, having 60+ 6TB or 8TB drives on one controller, scanner won't be able to complete scans on all drives in a period of 30 days...
cryodream
and
