Newest build.
Where can we get this latest build?
Not sure if we are supposed to share this knowledge but if you look at the download location and use some common sense all builds are available. The 378 build is the ones with all the ACD optimizations that fixed EVERYTHING.
Here is to hoping they release officially soon
Also that uses a new version of the cloud drive i believe so its not forward or backward compatible.
All this is at your own risk.
Glad to hear it!
And as wbadminuser has mentioned, we don't really hide the download location. It's almost clear text.
However, just be warned, that these are internal beta builds, and some may break things and cause your system to BSOD.  It's best to ask for a recommended build, so that we can refer you to a "good" build.
That said, here's the link:
http://dl.covecube.com/CloudDriveWindows/beta/download/
And the 1.0.0.378 is the latest build ATM, and shoudl be fairly stable.
