I have 8 hard drives. I was using FlexRaid with 6 drives as DRUs and 2 as PPUs. All DRUs have data on it, mostly half full, and was using FlexRaid pooling.
I have moved away from FlexRaid and will go with Stablebit Scanner and DrivePool with SnapRaid. Before running SnapRaid, I want to setup the DrivePool.
In FlexRaid pooling, one drive letter would appear showing all files from the 6 drives and the drives letter unmounted using NTFS folders. It was easier to just map 1 drive letter in XBMC or for network shares. I created my base folder before pooling so that I could have new files go into those folders and on to specific drives, which seems to work for the most part.
How does this work with DrivePool? I created the pool, but the pool is empty, which I read would happen. The drives also remain individually so that I can read and manage the existing data. I also disable balancing to keep the files where they are for the most part. If you have data, is the pool on a go forward basis only and mostly for duplication functions?
How can I make it work like I had with FlexRaid? Do I move the files from the individual drives to the pool, eventually emptying my individual drives? Do i then forget about balancing or not and DrivePool will decide everything? Can i unmount drive letters from the individual drives after the pool is created or should it be done before.
If I need to completely rethink pooling to a new way, how do people use it here?
abba77
