StableBit.com Downtime ×
Drivepool+Snapraid Balancing due to Damaged Drive
murphdogg
Recently moved and didn’t have my Drivepool+Snapraid server on for a few months (I also have Scanner).  Finally got it up and running again and noticed Drivepool was attempting to balance.  I thought I had all balancing turned off, but realized one of the drives was now damaged so Drivepool was using the “allow balancing plug-ins to force immediate balancing” via Stablebit Scanner (my understanding is it was trying to move files out of the damaged drive).
Should I not have “allow balancing plug-ins to force immediate balancing” checked (and not have the Scanner plug-in active) since Snapraid will recreate the files on the new replacement drive?  I get that it can be helpful for Drivepool to remove files off a damaged drive, but since I use this with Snapraid, isn’t it better to just have Snapraid recreate the files on a new drive?  If Drivepool moves files from the damaged drive, that would just mess up sync and add “new” files to the other drives?  Is my understanding correct?
That's what do. I just pull the drive out of the pool.  Sometimes I copy as much as I can to the new drive (faster).   Then restore the rest.     I also use snapshot Raid on my server (FlexRaid).  It still works marvelously well.
