Storage chunk size not beyond 1GB
9 answers to this question
Did you create a local cache as well (disabled by default on the local provider).
And could you grab the logs from StableBit CloudDrive?
Namely, just steps #7-10.
Also, do you have any antivirus, backup or other disk tools installed on the system?
And could you do this: http://wiki.covecube.com/StableBit_DrivePool_Q2159701
Log has been uploaded.  My test is on a fresh VM with Windows7 installed.  No AV or additional software is installed.  Just Stablebit Clouddrive and DrivePool.
Microsoft Windows [Version 6.1.7601]
Copyright © 2009 Microsoft Corporation.  All rights reserved.
C:\Windows\system32>fltmc
Filter Name                     Num Instances    Altitude    Frame
luafv                                   1       135000         0
FileInfo                                8        45000         0
Create new cloud drive (example 100GB), in the advanced settings, select "Storage chunk size" drop down.  Tried choosing a size bigger than 1GB, nothing happens after hitting create button.
Thoughts?
This actually appears to have been two issues.
http://dl.covecube.com/CloudDriveWindows/beta/download/changes.txt
It's issue #17677, for the fixes listed here.
Could you download the latest version, and verify that it resolves the issues for you:
32-bit: http://dl.covecube.com/CloudDriveWindows/beta/download/StableBit.CloudDrive_1.0.0.288_x86_BETA.exe
64-bit: http://dl.covecube.com/CloudDriveWindows/beta/download/StableBit.CloudDrive_1.0.0.288_x64_BETA.exe
