Flexraid and stablebit
Bjur
 Share
Hi i have a question. I have used flexraid with drivepool. One of my drives died and have now restored it
2. If I want to move the files into a drivepool can I just move direct from drive to folder or should I move to the drivepool letter?
First, I'm sorry to hear about your drive dying.
As for moving the files, yes, you can move the files directly into the "PoolPart" folder. The caveat is that you MUST remeasure the pool after doing so (open the UI, click on "Pool Options" and select "Remeasure").
If you don't do this, it can cause issues with the balancing engine, the duplication code, and the pool in general (where to place files, etc).
 Share
