Jasper Posted May 26, 2015 Share Posted May 26, 2015 Currently they are mounted as drive letters. Can this be changes to folders without data loss? Thanks Quote Link to comment Share on other sites More sharing options...
0 Christopher (Drashna) Posted May 26, 2015 Share Posted May 26, 2015 I'm assuming you mean the disks in the pool. If that is the case, then absolutely. In fact, we have a guide for that. http://wiki.covecube.com/StableBit_DrivePool_Q4822624 In fact, you could remove the drive letter and not mount the drive and DrivePool won't have issues with that either. Quote Link to comment Share on other sites More sharing options...
0 Jasper Posted May 26, 2015 Author Share Posted May 26, 2015 Once again, thank you sir. Explorer is now much cleaner. Quote Link to comment Share on other sites More sharing options...
0 Christopher (Drashna) Posted May 26, 2015 Share Posted May 26, 2015 You are very welcome, and yeah, it definitely helps keep the system cleaner. I have 15 drives in my pool, so I definitely understand! Quote Link to comment Share on other sites More sharing options...
Jasper
Thanks
