How do I start troubleshooting this? The drive that has 71.9 gb in use hasn't moved in months and all of the others don't seem to be balancing well.  I am not using duplication.
You could try forcing a remeasure: Manage Pool -> Re-measure.
Otherwise, you could take a look at Manage Pool -> Balancing and look through the Settings, Balancers and File Placement tabs to see if anything looks responsible.
If all of the above fails, and you don't mind having to retweak anything to your preferences, there is also (cog icon) -> Troubleshooting -> Reset All Settings which will reset all of the balancing and application preferences to default values while leaving your pool(s) intact.
