StableBit.com Downtime ×
Problem with Google Drive
iazriel
Hi. I updated drivepool to latest version 2.3.2.1493 and I am having issues with Google Drive. Each time I restart Windows, Google Drive can't find the synced folders and asks to relocate them. Even if I do that, drive keeps disconnecting and reconnecting continuously. I completely removed any files I had on google drive, signed off and completely uninstalling/reinstalling/resyncing had no effect, google drive keeps doing that with every Windows restart. Note that the problem occurs only with folders I sync with Google Drive and not Google Photos. Any ideas please?
Edit: Acronis True Image backup also exhibits issues with backup to my pooled drive, it only worked after the 3rd time I manually started it
No. I have informed the team here and they contacted Google for the matter but there is no response from Google. I just stopped and will stop using Google drive and move on to another service.
I wonder if I should switch to another "combine-local-disks-solution" instead. I do love the feature of easy duplikation of specific folders.
Rclone seems to work fine though, but I don't know if they have as seamless sync function as native Google Drive sync.
