GiuseppeChillemi Posted January 26, 2015 Share Posted January 26, 2015 Hi, on your site I find only 1 or 12 licenses purchase options. There is nothing in the middle. I am interested into purchasing 2 or 3 licenses. Giuseppe Chillemi Quote Link to comment Share on other sites More sharing options...
0 Christopher (Drashna) Posted January 28, 2015 Share Posted January 28, 2015 There should be a "x1 (change)" option in the top, left side of the panel. Clicking on "Change" should allow you to specify any number between 1 and 10). However, this only appears for StableBit DrivePool or StableBit Scanner, but not for the combo. If you want multiple of each, that's a bit more complicated (and we apologize for that). In this case, buy two of the DrivePool license. Then go to buy the Scanner licenses. If you don't see the combo item (Scanner+DrivePool), then you should get the discounted price right away.Otherwise scroll down until you see the "Already own one of our products" and put in your newly purchased Activation ID and hit the "apply" button. This will refresh the page and show the discounted price. (I apologize if you don't want Scanner as well, but I wanted to make sure the info was presented right away, instead of having to ask and wait for a reply). Regards Quote Link to comment Share on other sites More sharing options...
GiuseppeChillemi
Giuseppe Chillemi
