I am using DrivePool to manage a rather large movie collection. This movie collection contains my rips of Blu-Rays that I own. I do not rip them as ISO as I prefer to mount the folder directly using my playback software, as opposed to having to mount the ISO then play the drive with the player directly. Its just easier. As such I get 45GB folders where there are TONS and TONS of small files. I just went through a failure of the Pool due to a disaster with a eSATA card but due to the mechanism that you use to store the files, they appear to all be there. However, some of the blu-rays are on disk1, some on disk 2, some on disk 3 etc to a total of 15 disks (and my pool will just keep getting bigger from there).
I am in the process of re-building the drivepool and I have to take the old disks and copy them one by one back to the new pool and merge the folders together.
What I would like is an option that says Keep Folders Together and be able to mark a single folder and being kept together. That way when I copy say the movie 300 to drivepool I can mark the folder as kept together and even if its duplicated it would be duplicated as a whole on another disk. I Am not 100% certain this could be done with a balancer algorithm. I am a programmer so if the way forward is to build a custom balancer, I could write this. However I thought this might be a good core feature for the software to have itself. It would make the data for single folders so much more recoverable in the event of a pool failure or a drive failure.
wizengamot
