Hi. I am trying to re-purpose my home file server to be a little more robust, and I thought I would install DrivePool to help. But I can not get the installation to launch. Instead, I get an error saying that I require a (newer?) version of the "kernel-mode driver framework." For the record, the server is a 32 bit instance of 2008 server. If I recall correctly, there is no R2 release for the 32 bit version of windows server 2008, so this is as far as I can go.
When I try to find an installation of MS update 970158, I find it no longer available; I presume it was superceded.
When I try to manually install the update for 2685811, which appears to be the current 1.11 framework, I have an error saying something like "this update is not for your system." To be sure, I have tried the "all x86" update, and the other 2008 and win 7 64 updates, for good measure.
bedowyn
So... am I doomed? Any help is very welcome!
Thanks
-AA
7 answers to this question
