I am looking for some suggestions on the correct settings for have an SSD cache and file placement rules.
Here is what I have:
1x 500 GB SSD (2.5)
1x 1TB SSD (2.5)
1x 1TB NVMe drive
8x Archive Disks
I am looking to have at least one of the SSD dedicated as the cache drive
I would like a particular folder folder to just be placed on two of the SSDs for primary and duplicated files. I don't want this folder to go on spinning rust disks ever. These two drives can also be used as SSD cache if possible as well
All other files can go to SSD cache then to spinning archive disks during balancing
What are the best possible settings for this. I have tried a lot of thing but It seems like the files keep getting moved around to the spinning archive disks (the folder mentioned above)
electricpol
1x 500 GB SSD (2.5)
1x 1TB SSD (2.5)
1x 1TB NVMe drive
8x Archive Disks
