I've an issue where no matter how many fans and maxing out the speed setting on the fans the hard drives are getting to over 40c. I've set the windows sleep timer for all the disks in Advanced Power to sleep in 1 minute but, this isn't happening and I believe this is due to DrivePool somehow making the OS think the disks are in use when they are in fact idle. I'm currently running 8x8tb pool and also a 4*12tb pool and both pools have exactly the same problem.
Do you think this is a possibility? If so, any tips on how I might be able to let the disks sleep when not being used by anything other than the DrivePool service?
stuza 0
Product: StableBit DrivePool
Version: 2.2.4.1162
6 answers to this question
