kjay
Conflicting SMART Warning
I am getting conflicting SMART warnings on one drive in a WHS2011.
When I check the drive everything is ok, but 15 minutes later a warning pops up.
The drive isn't that old and CHKDSK shows no problems.
I am using Scanner version 2.4.0.2929.
Any advice would be appreciated...
Thanks.
These are two different disks? From the looks if it, they are, but I can't tell for sure.
However, at the bottom of the SMART info screen (any disk), could you check the "Submit to Bitflock" checkbox and either open a ticket (http://stablebit.com/Contact) or PM me the BitFlock ID, and we'll see if we can fix the issue.
