I've been thinking about a new setup, and I wanted to float an idea to see if it works (pros/cons). Basically, right now, I have my clouddrive mounted to a single Optane SSD (C:). This works great with speeds, but the drive is limited to 1TB, and with slow upload, this drive is full almost always, so it's hard to copy new data over. For this purpose, I have a bunch of HDDs that I added to a DrivePool pool along with the CloudDrive, and I copy over new data to those pools before manually moving it to the PoolPart folder in C: when the most recent data is uploaded. It is manual and cumbersome.
Could I do something like this instead? I create a pool of my HDDs, then add that to the CloudDrive pool. I set up the CloudDrive pool to download new data to the HDD pool, and then use the plugin to move data from the HDD pool to the CloudDrives? This way, my pool sees all the data, but the underlying locations are being managed automatically.
If this scenario is feasible, I do have a few questions.
1. If I have a file on the HDD portion, and I do a "move" via my Pool, will it remain on the HDD portion? Will it remain on the same disk it was downloaded to initially?
2. Can I control the plugin so it moves to CloudDrives based on the cache drive space? The CloudDrives will always look empty/have tons of space but my underlying cache may not. I am concerned that the plugin will constantly be trying to move data to the cache drive, resulting in it being full 100% of the time and slowing writes down.
RG9400
