  • 1
Trying to restore old WHS backup using whsdbdatadump
Tecno_Geek
 Share
I long ago made the switch from WHS to a Win 10 build with Stablebit DrivePool.  I recently found a few files that I need to restore to an older version.  I kept the client backup folder intact, and I see the PC and the dates of the backups when I run the whsdbdatadump command.  However, each time I run it I get an error: "Unhandled Exception: System.OverflowException: Arithmetic operation resulted in an overflow."
Looking for advice or perhaps another tool that might work?  Thanks!
That may be an issue with the version of the Client Backup database.
Are you using this on?
http://wiki.covecube.com/WhsDbDataDump_2.0
If so, that may be why, if you were using WHS2011.  In that case, try:
http://dl.covecube.com/WhsDbDataDump/BETA/WhsDbDataDump-1_0_0_6-BETA.zip
 Share
