I've read quite a few posts, but they are a couple of years old now.
Could someone please confirm the best settings for CloudDrive for Plex? The GDrive will be used exclusively for media. Mostly 1080p, but would be great if I could get 4K working too (not remuxes).
Also the chunk size?
My internet connection is 80Mbps down, 18Mbps up if that has any bearing on the settings.
Thanks.
Well, the 80mbps down may cause issues with 4k.
Aside that, For the storage chunks, the largest that you can use.
DL Threads: 5
Minimum Download Size: 20MB
Prefetch Trigger: 5MB
Prefetch Forward: 80MB
Prefetch Window: 30s
That should be good.  If not, try upping the download threads and forward size (the forward should be about 75% of dl threads times min download size)
