joergschurig Posted April 29, 2019 Share Posted April 29, 2019 Hello , i have updated my OS to Windows 10. When i copied files to the Pool and when i open files from the pool it takes o long, long, long time. Even for very small files. Before with Windows 7 it takes verry fast. What can this for a problem?? regards Jörg info.pdf Quote Link to comment Share on other sites More sharing options...
0 Christopher (Drashna) Posted April 29, 2019 Share Posted April 29, 2019 Does this happen with the underlying disks in the pool? If so, then it may be a problem with one or more of the underlying disks. Also, is this over a network share? otherwise, could you run the StableBit Troubleshooter on the system in question? http://wiki.covecube.com/StableBit_Troubleshooter And use "4315" as the Contact ID request. Quote Link to comment Share on other sites More sharing options...
joergschurig
Hello ,
regards Jörg
info.pdf
