skapy Posted April 25, 2019 Share Posted April 25, 2019 Hello, i have a gdrive business account and my created clouddrive is 99% full. Can i create a 2nd clouddrive on the same gdrive account without any problems? If possible: Any thinks i should take care for during creating a 2nd clouddrive? thanks in advantage Quote Link to comment Share on other sites More sharing options...
0 steffenmand Posted April 25, 2019 Share Posted April 25, 2019 9 hours ago, skapy said: Hello, i have a gdrive business account and my created clouddrive is 99% full. Can i create a 2nd clouddrive on the same gdrive account without any problems? If possible: Any thinks i should take care for during creating a 2nd clouddrive? thanks in advantage you can do several drives with no problem. just note the limitations for upload, api calls etc will be shared between the drives Quote Link to comment Share on other sites More sharing options...
0 srcrist Posted April 25, 2019 Share Posted April 25, 2019 12 hours ago, skapy said: Hello, i have a gdrive business account and my created clouddrive is 99% full. Can i create a 2nd clouddrive on the same gdrive account without any problems? If possible: Any thinks i should take care for during creating a 2nd clouddrive? thanks in advantage You can, but if you're going to be using it for the same purpose, I would suggest enlarging the drive and adding a second volume to the same drive instead. This make cache and performance management easier, and it's all the same to CloudDrive. It doesn't care if the information is on two volumes or twenty. Quote Link to comment Share on other sites More sharing options...
0 skapy Posted April 26, 2019 Author Share Posted April 26, 2019 10 hours ago, srcrist said: You can, but if you're going to be using it for the same purpose, I would suggest enlarging the drive and adding a second volume to the same drive instead. This make cache and performance management easier, and it's all the same to CloudDrive. It doesn't care if the information is on two volumes or twenty. The first drive will now only be attached on one pc and i only need access there. The uploads to the 2nd drive will be done from another pc so i think its better to create a 2nd drive. Thanks for your answer! Quote Link to comment Share on other sites More sharing options...
0 skapy Posted April 26, 2019 Author Share Posted April 26, 2019 12 hours ago, steffenmand said: you can do several drives with no problem. just note the limitations for upload, api calls etc will be shared between the drives Thanks! Quote Link to comment Share on other sites More sharing options...
skapy
Hello,
thanks in advantage
