For the past couple of months, I've had an issue which I found out today only occurs with network file shares that are on my drive pool. I am able to connect to these file shares just fine as well as read from them, however; if i try to write to them or edit a file within one, the workstation (system that hosts the share) immediately bluescreens, bugchecks, dumps, then restarts.
I run both DrivePool 2.2.0.906 as well as Scanner which scans as needed at night. I have all performance options enabled except for "Bypass file system filters" plus use the SSD plugin. Balancing is not occurring when the issue happens. Other than that, everything is pretty much default as I don't even duplicate anything. The pool is 43.5tb comprised of 12 platters and a single SSD. It works great other than this issue.
I'm happy to submit and logs or whatnot from the app, but wanted to post first to see if this was a known issue with workaround. DrivePool aside, below is the evidence that I've collected from the OS which is Windows 10 1803 x64.
Event Logs
The computer has rebooted from a bugcheck. The bugcheck was: 0x00000019 (0x0000000000000020, 0xffffe6871f9fd310
I loaded the dumps it created in WinDbg. It contains lots of data, but below is a summary - the 5th line from the bottom is what caught my eye.
Microsoft (R) Windows Debugger Version 10.0.18239.1000 AMD64Copyright (c) Microsoft Corporation. All rights reserved.Loading Dump File [D:\101618-45984-01.dmp]Mini Kernel Dump File: Only registers and stack trace are available************* Path validation summary **************Response Time (ms) LocationDeferred srv*Symbol search path is: srv*Executable search path is: Windows 10 Kernel Version 17134 MP (8 procs) Free x64Product: WinNt, suite: TerminalServer SingleUserTSBuilt by: 17134.1.amd64fre.rs4_release.180410-1804Machine Name:Kernel base = 0xfffff800`f6293000 PsLoadedModuleList = 0xfffff800`f6641170Debug session time: Tue Oct 16 08:55:13.232 2018 (UTC - 5:00)System Uptime: 0 days 20:22:06.699Loading Kernel Symbols...............................................................................................................................................................................................................................................................................Loading User SymbolsLoading unloaded module list................ERROR: FindPlugIns 8007007bERROR: Some plugins may not be available [8007007b]******************************************************************************** ** Bugcheck Analysis ** ********************************************************************************Use !analyze -v to get detailed debugging information.BugCheck 19, {20, ffffe6871f9fd310, ffffe6871f9fd380, 407000c}*** WARNING: Unable to verify timestamp for covefs.sys*** ERROR: Module load completed but symbols could not be loaded for covefs.sys*** WARNING: Unable to verify checksum for win32k.sysProbably caused by : covefs.sys ( covefs+2eae1 )Followup: MachineOwner---------nt!KeBugCheckEx:fffff800`f643bca0 48894c2408 mov qword ptr [rsp+8],rcx ss:ffff850c`0c184b00=0000000000000019
bzowk
Hey Guys -
Event Logs
XML View
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Microsoft-Windows-WER-SystemErrorReporting" Guid="{ABCE23E7-DE45-4366-8631-84FA6C525952}" EventSourceName="BugCheck" />
<EventID Qualifiers="16384">1001</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2018-10-16T14:00:03.312566800Z" />
<EventRecordID>2223702</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>System</Channel>
<Computer>KelNetSVR</Computer>
<Security />
</System>
- <EventData>
<Data Name="param1">0x00000019 (0x0000000000000020, 0xffffe6871f9fd310, 0xffffe6871f9fd380, 0x000000000407000c)</Data>
<Data Name="param2">C:\WINDOWS\MEMORY.DMP</Data>
<Data Name="param3">df4e3200-9e5b-48ca-a497-62ed9c91ce3e</Data>
</EventData>
</Event>
Dump Files
Any thoughts or suggestions? Thanks!
