Just wanted to share what I saw today using my cloud drive with Google, I know they are marked as warnings, but the fact I see "failed" makes me a bit nervous.
Is this bad or a sign of bad things to come perhaps? Or just normal behavior to safely ignore?
15:26:27.4: Warning: 0 : [ApiGoogleDrive:37] Google Drive returned error: [unable to parse]
15:26:27.4: Warning: 0 : [ApiHttp:37] HTTP protocol exception (Code=InternalServerError).
15:26:27.4: Warning: 0 : [ReadModifyWriteRecoveryImplementation:37] [W] Failed write (Chunk:50901, Offset:0x00000000 Length:0x01400500). HTTP Status InternalServerError
15:26:27.6: Warning: 0 : [TemporaryWritesImplementation:37] Error performing read-modify-write, marking as failed (Chunk=50901, Offset=0x00000000, Length=0x01400500). HTTP Status InternalServerError
15:26:27.6: Warning: 0 : [WholeChunkIoImplementation:37] Error on write when performing master partial write. HTTP Status InternalServerError
15:26:27.6: Warning: 0 : [WholeChunkIoImplementation:37] Error when performing master partial write. HTTP Status InternalServerError
15:26:27.6: Warning: 0 : [IoManager:37] HTTP error (InternalServerError) performing Write I/O operation on provider.
15:26:27.6: Warning: 0 : [IoManager:37] Error performing read-modify-write I/O operation on provider. Retrying. HTTP Status InternalServerError
15:26:31.9: Warning: 0 : [ApiGoogleDrive:37] Google Drive returned error (notFound): File not found: 1MhgSaAvhGpIjRBQnrE6ngWuIvXNzM4P4.
15:26:31.9: Warning: 0 : [ApiHttp:37] HTTP protocol exception (Code=NotFound).
15:26:38.8: Information: 0 : [IoManager:48] All writes complete.
I did see similar messages for another Chunk:138 twice as well
Appreciate the help!
