Drive was forced to unmount because it couldn't read data from the provider
Recently upgraded my clouddrive and i can't seem to recover or connect to my account anymore. Keep getting the same error of the drive being forced to unmount.
8 answers to this question
Updated to the latest version 1.0.2.963, Google drive, there is not errors shown. Just saying drive cannot be mounted even in technical details there is no error being sent back. Everytime i seem to download an update this happens. Last time it destroyed my drive, I think i am going to stop update altogether.
That's .... not typical, at all.  In fact, I think that's the only time I've seen/heard this, actually.
If you would, open a ticket, actually.
And if you could, run the StableBit Troubleshooter: http://wiki.covecube.com/StableBit_Troubleshooter
If you open a ticket, use that ID, otherwise, use "3387" as the ID.
Also, if you could, enable web logging and reproduce the issue: http://wiki.covecube.com/StableBit_CloudDrive_Web_Logs
Alright sent the tickets, and the web logging and troubleshooter. Thanks for the help. Turns out my connection wasn't  connected to Google Drive for some reason, after connecting it. All my drives are destroyed except for one, which should not be the case.
