Good afternoon!
I install DrivePool on Server 2012, ip:192.168.137.50   and try to connect them from local client (windows 8.1).
On local client i install same  version of Drive pool, rename  file RemoteControl.default.xml  to RemoteControl.xml and
add peer to them : <Peer>192.168.137.50:27525</Peer>
Both firewall (client and server) are off.
TCP connect from client to sever on port 27525 is successful.
On local client i run DrivePool.UI.exe  and they say permanently 'Connecting to service'.
How i can connect to remote Drive Pool ?
