I am almost sure, I am missing something here, but since DP is working so flawlessly in general, I cannot recall if what I see is a problem from my side of the keyboard or from DP.
Did an upgrade to 2.2.0.798 BETA to solve a problem with being unable to temporarily remove a good drive from the pool, as stated elsewhere here in the forums.
After that, DP (re-)gathered all data and everything looked well.
Now, a couple of days and reboots later, I am seeing the effect, that some files are not accessible from the pool.
Explorer sees them, but opening gives an Error, that the file is not there.
I normally don't use the native drives, just the pool...after enabling the disks and accessing the pool-part folders directly, the files are there and can be accessed, as expected.
However, the problem with accessing the files via the Pool persists.
I issued the command to re-gather the pool information manually, several times to no avail.
Since when I enabled the native disks with drive letters, a large part is now shown as "other" instead of duplicated/non-duplicated...don't know if this is related though.
...what is the recommended procedure to get DP up to the correct state and functioning again?
p3x-749
I am on Win10-Pro 64bit BTW.
TIA,
Fred
22 answers to this question
