I am considering purchasing and installing DrivePool in the following situation:
I am involved in media sound production and have several hundred "virtual instruments". Each of these is in it's own folder with multiple subfolders. The total size of each folder is on the order of several gigabytes to 1.5 TB. These are currently distributed across 4 m.2 nvme drives and 2 sata SSDs.
There is no easy, unified way to index these instruments - some only run within other programs (i.e. Kontakt, Halion while others are their own virtual instrument which I load into a DAW.
So, I'd like to put them all on one virtual drive so that rather than searching through six drives looking for something, I can search through one.
1) If a create a pool with all 6 disks and add the entire contents of all six to the pool, they will stay right where they are on the physical disks, right?
2) Can I create a rule such that when I add a new virtual instrument folder that the whole thing goes on one physical disk? For these things, if you are missing one file, the whole folder is useless. In the event of drive failure, this would simplify recovery.
KenVives
Hello,
Thanks so much for your help!
