Quick question... so CloudDrive with encryption enabled, is that included in the "types" of programs that can cause issues with "Bypass file system filters" checked, or is that not considered an issue because the two programs are kind of built to be compatible with each other?
Basically... checked or unchecked on a DrivePool if using it to pool encrypted CloudDrives.
wid_sbdp
