SaintTDI Posted April 8, 2024 Posted April 8, 2024 Hi all! This night Stablebit Scanner sent me 2 emails that my 980 Pro is Damaged. It's the NVME where Windows is installed This is the report: And this is the NVMe Health Report: It's the first time that happens, actually I don't know what to do Is it better that I start the file scan ? What else can I do? Thanks for the support! Quote
0 Christopher (Drashna) Posted April 8, 2024 Posted April 8, 2024 Given the read errors and the NVMe Health warning, I would definitely recommend replacing the drive. Quote
0 SaintTDI Posted April 8, 2024 Author Posted April 8, 2024 35 minutes ago, Christopher (Drashna) said: Given the read errors and the NVMe Health warning, I would definitely recommend replacing the drive. Thanks for the reply! mmm yep I thought that it would be the only option... but do I have time? Do you think I can wait about 15 days? And to replace the drive, can I clone this old 980 on a new 990 ? Or is better that I install everything again? Quote
0 Christopher (Drashna) Posted April 11, 2024 Posted April 11, 2024 That's a hard question to answer. SSDs tend to be fast, including in how they fail. But given this, I suspect that you might have some time. However, back up the drive, for sure! Even if you can't restore/clone the drive, you'd be able to recover settings and such from it. But ideally, you could restore from it. And cloning the drive should be fine. Most everything is SSD aware anymore, so shouldn't be an issue. But also, sometimes a clean install is nice. Quote
0 SaintTDI Posted April 15, 2024 Author Posted April 15, 2024 On 4/11/2024 at 9:57 PM, Christopher (Drashna) said: That's a hard question to answer. SSDs tend to be fast, including in how they fail. But given this, I suspect that you might have some time. However, back up the drive, for sure! Even if you can't restore/clone the drive, you'd be able to recover settings and such from it. But ideally, you could restore from it. And cloning the drive should be fine. Most everything is SSD aware anymore, so shouldn't be an issue. But also, sometimes a clean install is nice. Ok! Thank you very much Quote
SaintTDI
Hi all!
This is the report:
