I was using Drivepool (V.2.1.1.561) for aprx. 3 Month without any Problems. Last Week I copied a big File (800GB in one File) to my Drivepool, and Drivepool is not able to balance the Pool.
My Drivepool use 2 Disks (1T each named CACHE A and CACHE as cache, and 2 Disks (8T each named “ARCHIV A 1” and “ARCHIVE B 1”).I use only the “SSD Optmizer” as Balancer.
I am able to copy the big file to the pool without any problem. I can see the file on the 2 CACHE Disks. After finishing the copy, the pool start to balance.(I can see the activity Led’s on the 2 Disks (one ARCHIV & one CACHE)) The Progress continues to something about 2% then restarts without any error again with 0.2% and so on. If the Process starts again the Target Drive is changing (I can see this on the Activity Led of the Drive.)
In the Log File I can find a Warning like:
DrivePool.Service.exeWarning0[FileMover] Error moving '\\?\Volume{9bd3e1c2-cfee-4611-8d32-3d37ba293688}\PoolPart.aaa84030-e4de-4a84-ac23-09c7c2711284\Archiv\Backup Veeam\PAP Alle Produktiven VM2016-04-10T143651.vbk' to '\\?\Volume{514e8456-d9c0-4fe7-870d-b082b2fc97b5}\PoolPart.838af591-1ccb-410d-9658-06ec3463365d\Archiv\Backup Veeam\PAP Alle Produktiven VM2016-04-10T143651.vbk'. Falscher Parameter2016-04-10 17:37:17Z45157247662
If I delete the big file, select “Neu erfassen…” in the Pool Options, my cache drives are empty, and the pool seems to be ok.
pap
Hi
My Drivepool use 2 Disks (1T each named CACHE A and CACHE as cache, and 2 Disks (8T each named “ARCHIV A 1” and “ARCHIVE B 1”). I use only the “SSD Optmizer” as Balancer.
I am able to copy the big file to the pool without any problem. I can see the file on the 2 CACHE Disks. After finishing the copy, the pool start to balance. (I can see the activity Led’s on the 2 Disks (one ARCHIV & one CACHE)) The Progress continues to something about 2% then restarts without any error again with 0.2% and so on. If the Process starts again the Target Drive is changing (I can see this on the Activity Led of the Drive.)
DrivePool.Service.exe Warning 0 [FileMover] Error moving '\\?\Volume{9bd3e1c2-cfee-4611-8d32-3d37ba293688}\PoolPart.aaa84030-e4de-4a84-ac23-09c7c2711284\Archiv\Backup Veeam\PAP Alle Produktiven VM2016-04-10T143651.vbk' to '\\?\Volume{514e8456-d9c0-4fe7-870d-b082b2fc97b5}\PoolPart.838af591-1ccb-410d-9658-06ec3463365d\Archiv\Backup Veeam\PAP Alle Produktiven VM2016-04-10T143651.vbk'. Falscher Parameter 2016-04-10 17:37:17Z 45157247662
The Service Folder as zip file is attached.
Thanks for Help
Best Regards from Austria
Peter
Service.zip
