RFOneWatt 27 Posted March 27, 2016 Share Posted March 27, 2016 Good Day! I have a Drivepool system and every time I reboot the server I get a notification that a specific (long gone) drive is missing. Everything is is fine, been ignoring the error for months. Any ideas? ~RF Quote Link to post Share on other sites
0 Christopher (Drashna) 623 Posted March 28, 2016 Share Posted March 28, 2016 What version of StableBit DrivePool are you using? If you're using the release version (2.1.1.561), there was an issue with this that is fixed in the Public beta version. Barring the public beta build, you can reset the settings and this will fix the issue (but this resets the balancing settings and the file placement rules. http://wiki.covecube.com/StableBit_DrivePool_Q2299585B Quote Link to post Share on other sites
RFOneWatt 27
Good Day!
Any ideas?
~RF
