Richard Pendered Posted March 25, 2024 Posted March 25, 2024 Drive Pool gives me the following error and I have no idea what to do to rebuild my pool. Quote
0 Christopher (Drashna) Posted March 26, 2024 Posted March 26, 2024 Simplest option? Just empyt the recycle bin. That will remove said file. As for the specific issue, I would recommend running a CHKDSK pass of all of the pooled disks, and then re-measure the pool. If the issue continues, then please open a ticket at https://stablebit.com/Contact Quote
0 Richard Pendered Posted March 28, 2024 Author Posted March 28, 2024 Not sure which Recycle bin to remove (the individual drive, or the pool itself)? I've cleared the individual drives, but there seems to be 16Gb in the pooled recycle that I am not sure that i want to remove/lose. Did a checkdisk and now have a weird issue where a disk is lost, but is able to be added. See screenshot below. I'm not sure how I can move forward with this without creating a new pool and moving data manually. If someone can give me a steer that would be a help. Quote
0 Christopher (Drashna) Posted March 28, 2024 Posted March 28, 2024 Try rebooting. If that doesn't help, try resetting the settings in StableBit DrivePool. https://wiki.covecube.com/StableBit_DrivePool_Q2299585B If that doesn't help with the missing disk, remove the disk in the UI, and then do this: https://wiki.covecube.com/StableBit_DrivePool_F1655 And the recycle bin should be the one on the desktop. It's a combined list of all of the drive's recycle bin. Quote
Richard Pendered
