That is, problems arise, surprising nobody at all.
Here's the deal:
I had a workable Win7 setup with Drivepool, everything was going fine... decided to move to Linux, heard that mergerfs + Greyhole + Openmediavault is pretty amazing, lots of packages that "just work" from a web interface...
Okay.
Installed OMV, bought 2 more drives. Formatted them EXT4, then started moving data to them then reformatting the now-empty NTFS partition to an EXT4 one. Did this for all my drives.
Messed around with OMV, was impossible to get certain things to work right... okay, ready to move back to Windows.
Got Diskinternals' Linux Reader software to copy the data from EXT4 partitions to NTFS, downloaded DrivePool, but when setting it up, all my data now shows as "other!"
All of it... tried mounting the discrete drives and resetting permissions (both through drive letters **and** NTFS folder mounts) but still everything is showing as "other."
Superpsych0
Here's the deal:
Okay.
Help!
